drew72ca said:If you go back a page on this thread you will see how I did it so they can be on, even if the parking lights are not. I tapped into the cigarette lighter to provide power to the relay so whenever my key is on, the lights can be on, but they are controlled by the switch. Take a look at the pics and my instructions if you want to do it this way. It's a similar process with a couple little differences, but the pictures and my description should help ya do it.
Andy
luvmyprotege5 said:Hey thanx for the how-to. What I did was hook the red wire from the relay to true ignition. If you have an alarm your alarms ignition wire should be hooked to this already so all you really need to do is tap into that wire. This way my fogs are on whenever my car is on. Then i just grounded the red/white wire from the switch to a chassie ground. Still have full controll of my fogs when I want with the switch. Even though I never turn them off I still can if I wanted to. Took like 15 minutes. Thanx again
The true ignition is a blue wire, maybe 10 or 12 gauge. You can find it under the dash right under the steering column. It will be comming from the ignition in a group of wires. Use a test light if you have one, the true ignition is the wire that does not shut off when you start the car.klieu said:Hi Everyone
I am not car enthusiast. How do I find the true ignition wire ? Where is it ? I would appreciate from your help, pictures are excellent if you have it
Thank you very much
albystyle said:hey guys,i broke my fog light switch was wondering if i can some how get the fogs to light up without the switch or mabey help connecting a toggle switch.thanx.. albert
albystyle said:well none of the local junkyards have any 3rd generations and the dealer wants almost $60.00.i'm probably better off using a toggle switch.do i need one with 2 or 4 connecters?does anyone know which wire is which,or how to connect the toggle?(sorry i'm a newbie).... thanks albystyle
albystyle said:thanks andy,i hooked up a switch with three prongs, the only problem is the foglights only light up with my parkings lights and shuts off with my low beams.i try every combo possible and blew 5 fuses.i guess i'll just live with that for now. thanks albert
albystyle said:well guys, got another problem....i just went and bought another stock switch and connected every thing as normal....(at least i hope so)....well now i lost my dash and parking lights....help! anybody! .........albystyle
andyfatsax said:All I want to do is cut out the DRL altogether! How ??? Can I just clip the YELLOW/GREEN wire connected to the parking brake switch and that will turn off the DRL? My new HID kit is freaking out cause it doesn't know what to do with the DRL signal.
