I've got 10,000 miles on my '18 cx 5, and the only thing that bothers me a bit is the brakes. They do the job fine, but just feel a little mushy. Any adjustments that can be made to address this?
Thanks much.
Bleed the brakes to see if this helps. Ed
No adjustments. Something to just get used to. They're mushy but they work.
This. I'll grant the brakes are not as what's the word...abrupt in their operation as other vehicles I have driven. But they do work.
Install steel braided lines in place of stock rubber, and give them a good bleeding. That should make a noticeable difference.
We*re not on a race track, regular brake pipes will easily withstand 100 bar (about 1500 psi) with minimal deformation. You can bend the calipers open at those pressures, adding to the give in the pedal. It really isn*t necessary on a modern car to modify the system. Mazda have added a large diameter servo to give a soft feel and here we are trying to undo it. ;-)
steel braided lines don't really do anything from a performance standpoint. But they do improve brake pedal feel. And they should last longer given that they aren't exposed rubber, which tends to degrade over time when exposed to the elements. Even EricTheCarGuy recommends them for any vehicle as a worthy upgrade.
I was going to call BS on them too but did some research, and yeah, they are legit. That said, I have also never ever ever had a brake line failure, even on 30+ year old cars. Never say it won't happen, but odds are I could enjoy a good meal instead. My brakes in my 2015 and 2019 felt fine, albeit, the 2015 needed a fluid change at 90K to feel that way. Not spongy, just not very grabby, but that's a quirk of ultra low-dust pads.
