- 2014 QX70 AWD
so.. city goes up. highway goes up.. and thus naturally... the average stays the same
must be that new math folks are talking about.
The 2018 is heavier then the 2017 - listed in another thread. About 38 pounds heavier if i recall, but not sure why.
Range stays the same, too. Something's not penciling out. Or somebody at the EPA forgot to change the range numbers on the "4WDs". How likely is it that it hasn't changed in four years? Who's got the tank cap specs?
Wait a minute. Why are we relying on EPA numbers [aside from there is no alternative]? Then why do we put any faith in their accuracy? I've NEVER had a car that got EPA rated mileage.
My 2016 AWD CX5 GT was averaging 27.5 when I traded it in. I seemed to be on the higher end amongst members here.
17 got all that. Exterior same. Interior same other then window switches. The 17 got the glass, too. NVH wasn't improved in 18, nor did it need to be as 17 is quiestest in class.Because of the noise isolation, which is a big improvement.
- the new exterior design is a lot better
- the interior is more sophisticated
- sound-insulating glasses
- power lift-tailgate
- front wiper de-icer
- heated steering wheel
For me the right choice is always 2018.
17s absorb bumps and imperfections better than 19sAre the 17 inch wheels a nicer ride than the 19 inch wheels?
I wonder if the 2 inch difference in wheel size plays a role in MPG since the taller tire will rotate less RPM?
Since the overall circumference of the tire and wheel between the 17" and 19" combos still remains the same between the two sizes, so does the RPM. It is the SIDEWALL height that is changed.
I see. So the only difference is in the look and the 17s offer better road cushion since the sidewall is taller. Short sidewalls tend to be stiffer but they do handle a little better on curves.
I'm completely satisfied with my '17; but if I were buying today I'd get the '18 for the minor updates (i.e. all windows auto-down and switches lit) and one less year of depreciation when/if traded.
