Brian_K's Build Thread
Those wheels look fantastic on the car. There is a guy selling a practically new set of them in our area, your photos aren't helping my wallet out any!
Let me know if I can help :)
haha i totally forgot you sold spacers, i'll send a pm your way
i like them a lot, but i just wish they were lighter and had a lower offset
Looks like my car.... But better!
Love the lug nuts and brake calipers
thanks!
"Less turbo bring removed" or "More turbo being installed"
Your Choice...
lol i'm only at 5psi right now and I'm planning on keeping there until i swap out the rods and pistons
Interior and engine bay shot. I'm gonna try to start cleaning up all the vac lines and hoses this weekend
love the p5 man looks real clean i wish i had the money to make mine look like this...does your new coolant resevoir leak? what did you put before adding the fitting? and did you add an over flow line or just the one at the bottom?
edit: and you should sell me your sls lock switch cover :D
CLEAN! My new favorite P5.
thanks man!
thank you :). No leaks so far, I just roughed up/cleaned the fitting and hole before adding some jbweld to seal everything up. There's just the line at the bottom and a small hole drilled into the cap for right now. I'll probably get around to modifying it more when i have more free time.
clean P5! What did you use to clean the engine bay? Thinking bout doing the same when the weather gets nicer. Mine looks beat
thanks, lol I just used water and a rag. I'm pretty lucky socal doesn't have any extreme weather conditions
Just a few small updates. Went down to a 40 series tire, not really liking it. I'll most likely be going back to a 45 series when i get new wheels. Also removed my turboxs type s bov.
Swapped out the oem oil drain plug for a magnetic one
swapped the ugly diy fender washers with some nice billet anodized gold ones
and just a rear shot of the car
adjusted both rear and front endlinks today, wiped it down with some quick detailer and took some photos. rear needs a bit of neg camber and i'd like to go lower but then i wont be able to get up my driveway lol
Latest posts
