GhostMercury
- MazdaSpeed 3 08.5
How do we install subs in our cars with the bose.
what if i only need it for 1 amp. is there a dif one
Good point, I forgot about that.- there are concerns that you will not get full frequency this way as the Bose sub may process/tweak/limit the signal. .
- You need to search for the Bose wiring diagrams to find the info.
I forget where I saw it but it is out there in several places.
I was told if you take the signal for the sub before it goes into the amp you don't need a hi low signal converter. Does anyone know if this is true?
I will go back and try to find the old wiring diagram, but no guarantee I can dig it out.
This thread, post #10. I know it is good for 2007, and I doubt it changed for 2008.
You do not need a LOC at all, and as far as RCA inputs to the amp, its easy get some soder and go to radio shack and make it yourself. If you dont want to soder, radio shack also has soderless RCA heads.
I like the adjustability the LOC gives on an installation. Just another way to fine tune things and make it more balanced.
