Mazdaspeed2oo35
600whp - 600wtq at 30 PSI
Hi, It's has been a while but it's time to present the new TBK Performance Mazdaspeed Monster, It's not done yet but it will be pretty soon, here are the list of specs, Pictures and numbers these Little Demon Child has put down by just putting everything together without tuning, or any adjustments, feel free to comment anything you think negative or positive, we are all here to share ideas... Let's get these party Started.....
The Car it's currently running at only 12 PSI without tunning, Adjustable Cam Gears and methanol Injection Kit and did 397 whp and 410wpt, those 3 important things have to still be done, and of course dyno it again. There is 2 Members of these community that can vouch how INSANE these baby is at only 12 psi and 397whp, i just can't imagine when the rest of stuff are installed and we up the boost to 30 PSI and tune by the best Hi performance shop i know. TBK Performance. the members are LUNATIK and ALEJO_NIN they can pretty tell their story about racing against the big boys and just going for a test drive.
Engine: FS-DE 2.0 Liter
1. Honed and polished Engine Block.
2. Blue Printed and Balance Engine + Head
3. Sandblasted and black Powder coated engine block.
4. Crankshaft balanced and Polished.
5. Aries Custom Forged Pistons Lower Compression 8.1:1
6. Pauter Forged Chromoly Rods
7. Clevite 77 Main Bearing Set
8. Clevite 77 Thrust Washer Set
9. Clevite 77 Connecting Rod Bearing
10. Cometic Thicker Head Gasket, New Engine Compression 8.0: 1
11. Greddy Timing Belt.
12. TBK Performance Custom Stage 3 FS-DE Head Blue Printed and Balanced to achieve 8,400 RPM Redline Limit.
13. TBK Performance Custom Turbo Dual Overhead Cams
14. TBK Performance 5 Angle Valve Job
15. TBK Performance Full Head Port and Polish Job
16. Ferrea 1mm Titanium Bigger Valves & Harder Valve Springs.
17. ARP Head Studs, ARP Washers, ARP Nuts.
18. SR Adjustable Cam Gears
19. ProtegeGarage Intake Manifold Single Runners with TBK Performance port & polish.
20. TBK Performance Port & Polish throtle body 60mm.
21. Throtle body Coolant Bypass
22. Unorthodox Ultralight S Underdrive Pulley.
23. Gates High Performance Engine Belts.
24. Apex Air diversion Plate radiator.
25. Mazda Millenia Supercharged PCV Valve.
26. Maxspeed Magnetic Oil drain Plug
27. Mazda Protege 5 Radiator
28. Ultra Slim HI Performance Radiator fans
29. Mazdaspeed 1.3 bar Radiator Cap.
30. Mazdaspeed BSpec Low Temp Thermostat
31. Mazdaspeed Gunmetal Oil Cap.
32. AWR 70a Bushings Front Motor Mount.
33. AWR 70a Bushings Rear Motor Mount.
34. Weapon R Engine Damper.
35. AEM Water/Methanol Injection Kit with 1 Galon Tank
36. Dual Walbo 255 in-tank and in-line Fuel Pumps.
37. RC 760cc High Impedance Injectors.
38. Perrin Fuel Rail.
39. Haltech E6X Stand Alone Engine Management Air/Fuel,Timing, launch Control and Anti-Lag Features.
40. Haltech 3 bar MAP Sensor.
41. Haltech E6X Shift Light
42. HKS Super Sequential V2 Blow Off Valve Adjustable.
43. HKS Earth Ground Cables System.
44. Mazdaspeed Positive Charging and Voltage Stabilizer.
45. AEM GT35 Turbo Filter
46. Spearco Front Mount Intercooler
47. TBK Performance Custom Chrome 3 Front Mount Intercooler Pipes & Flanges.
48. Turbonectics Clamps.
49. Hiboost GT35 Big Turbo Manifold + TBK Performance Port & Polish
50. Garrett GT3571R Turbo with Stainless Steel Water and Oil Lines
51. TBK Performance 3custom downpipe
52. TBK Performance Custom 3.25 Downpipe back Exhaust with 3.25 Resonator
53. HKS Hi Power Muffler Chrome
54. Tial 40mm External Chrome Wastegate.
55. NGK IX Iridium Sparkplugs ( One Step Colder )
56. Haltech Coil Packs.
57. K&N 1008 Oil Filter
58. Royal Purple 20W50 Fully Synthetic Oil
59. Lucas Synthetic Oil Stabilizer & Protection ( New Engine Formula ).
Drivetrain:
60. Complete Transmisin Internals Cryo Treated
61. Fidanza 7.5 lbs Flywheel.
62. DSS Level-2 Drive Axles
63. ACT Xtreme Stage 3 Racing Clutch.
64. ACT Xtreme Street Preassure Plate Disk.
65. Welded LSD front and back of it with Cryo Treatment
66. Racing Synchronizers with Cryo Treatment
67. TBK Performance Custom 600whp 3rd, 4th, Gears with Cryo Treatment
68. Techa-Fit Clutch Line.
69. Redline Shockproof Synchromesh Heavy-duty Transmission Synthetic Oil.
70. TWM Short Throw Shifter.
71. TWM Shifter Bushings.
Brakes:
72. Brembo Cross Drilled & Slotted Rotors.
73. Techa-Fit Stainless Steel Brake Lines.
74. Posi-Quiet Ceramic Low Dust Brake Pads.
75. Royal Purple Synthetic Brake Fluid.
Suspension:
76. TEIN Adjustable SuperStreet Coilover Suspension
77. GT Spec Aluminum Front Strut Brace
78. Racing Beat Front Lower Sway Bar.
79. AWR Front Lower Sway Bar Bushings.
80. AWR Adjustable Front End Links
81. GT Spec Aluminum Rear Strut Brace
82. Racing Beat Rear Lower Sway Bar.
83. AWR Rear Lower Sway Bar Bushings.
84. AWR Adjustable Rear End Links.
85. GT Spec Rear Trailing Link Set
Electronics & Interior Accessories:
86. OEM Mazdaspeed Classic Soft Trim 2 Tone Leather Interior Dark Charcoal with Titanium Gray + Titanium Gray Leather Door Panels.
87. Greddy Profec B Spec-II Eletronic Boost Controller (Silver).
88. Greddy Remote Switching System Steering wheel (Silver).
89. Greddy Full Auto Turbo Timer (Silver).
90. Maxspeed Engine Start Bottom (Blue).
91. Autometer Triple gauge pod (Black).
92. AEM Uego 6 in 1 Wideband Controller (White).
93. Auto Meter C2 Indiglow Pyrometer EGT 0-1600 Degree F.
94. Auto Meter C2 Indiglow 30 P.S.I Boost/Vacuum Gauge (White).
95. MRYELLERMP5 Custom Bezzel Dual Gauge Pod
96. Auto Meter C2 Indiglow Oil Preasure Gauge 0-100 PSI (White).
97. Auto Meter C2 Indiglow Fuel Preassure Gauge 0-100 PSI (White)
98. Maxspeed Cluster Indiglow Gauges 7 Colors with Dimmer (White)
99. Street Unit Cluster Polish Rings.
100. Maxspeed Chrome Cluster Bezzel.
101. Mazdaspeed Seat Belts Pads.
Lighting:
102. Euro Black Smoked Head Lights.
103. Bi-XENON Head Lights Kit. 8000k High & Low Beams.
104. Piaa Clear Rectangular Fog Lights.
105. XENON 8000k H3 Fog Light Bulbs.
106. Lexus IS350 LED Ultra White License Plate Bulbs.
107. Mazdaspeed Carbon Fiber License Plate Frame.
Wheels & Tires:
108. 2006 Mazda RX-8 Shinka Edition Wheels Gunmetal 18 X 8.
109. Nankang Ultra Sport NS-II Tires Z Rated 215/35/18.
110. SPEEDSHOP NITROGEN instead of air in tires
111. Gorilla Chrome Wheel Nuts.
112. Gorilla Chrome Wheel Locks.
Drivetrain:
Brakes:
Suspension:
Lighting:
Wheels & Tires:
