kicker22705
- 03.5 Ti MSP
i'll return tomorrow,, as i didn't install em yet. thanks for the heads up fellas.
Hope you can figure it out.
Kool most of those values in the 300 load range wont be hit so thats n/a. My car doesnt start to really make power untill 4k.
I honestly don't understand the logic behind going to a hotter plug with knock problems. please explain that to me?
I ran 7's in my protege from 3.5k on!
Colder plugs don't idle as well and are more prone to fouling. And need to be changed more often. Also they aren't good for cold starts.
I'm gonna guess you fouled one or two. Or your gap was too high. Your car will idle worse with colder plugs but shouldn't run bad
I agree Dana, I'm not calling bulls***, cause you know your stuff, but with knock generally a colder plug is the way to go. I had some ping with BKR5E's and went to the 7E's and it went away. (I only had the 5E's in for a day cause I dropped one of my new ones and smashed it so I had to use them for a day until I got a replacement.)
Some people just like to think the answer always needs to be complex. Keep it simple stupid is a great motto. At $1.99 a plug what does he have to lose?
I'm not saying that he shouldn't try the plugs, I agree he should. My question is why this might ring true if it works...
okay i pulled the old BKR7E out, and they looked pretty good. even tho i could head audible pinging multiple times while running these, they still show no signs of detonation. they look rather normal. i'll take some hi-res pics when i get a chance.
i ran the BKR6E, and so far it appears to have helped. i didn't hear any audible pinging before 12psi. at 12psi-13, it begins to creep back, but not as early, loud, or consistent as before.
so far they look to be working better than the BKR7E for me.
Another thing i noticed was, my AFR dropped quite a bit w/ these plugs. I used to run about 10.8-11.2 from 3k rpm, but now i'm running about 12.2 down to 11.2 from 3k rpm. I think if i richen it up in the middle it should help further.
this is with a new 1/2 tank of gas, after basically using up the little bit of 110/93 mix i had left over from last night. there is a possibility the small 110/93 remnant could have helped.
i'll make another update after i refill the tank.
Go figure.
I have a feeling the plugs may not be your only issue, but hell, it's a start. When will you have something that will allow you to monitor knock?
So it leaned you out? Interesting.
Oh, I'm sure it did.
Aye, keep us posted. Try the timing suggestion I posted earlier too.
1 easy possibility affecting the tune. Have you checked your timing belt and timing?
I noticed you have long rods. You should read this. You should probably adjust your timing map up some as suggested.
http://www.stahlheaders.com/Lit_Rod%20Length.htm
