- Completely Stock P5
What does your "static timing" refer to? You said it was +10.
Valid point. However, it looks like he has two maps that overlap each other. One is based on boost pressure and the other is based on RPM.
I've had bad experiences tuning on the boost retard maps before, since the readings vary a bit.
You could always try hard coding the timing in the RPM scale for diagnostic purposes. It's worked well for me in the past. Actually, I'd seriously suggest you do that, and zero out the map that retards based on boost pressure.
i can do that but do you think it will matter? if you look at my datalog sheet at the bottom of my first post, you can see the timing basically drops down to 10 in the whole area where it pings.
I honestly don't understand the logic behind going to a hotter plug with knock problems. please explain that to me?
I hear ya, but can it hurt to try? Like I said, I've been in the same situation before.
You've tried most of the obvious answers already, so you might as well try a few alternate ideas.
