Yes this is a TOUGH one. After breaking two swivel joints using my 3/8" rachet, I switched to 1/2" breaker bar and long extension and was able to break the bolts loose.
Remove the throttle body and cold pipe to clear some space to reach rear mount. Then remove the wire harness from the firewall. I had to cut off its lower stud to allow socket to fit over back mount bolt.
Access the engine bolt through the drivers wheel well (tire removed of course).
