Good day guys. I was going to load an audio CD in the changer and after I pushed the load/eject button on the console the screen is now stuck in the "open" or down position.
1. It went through it's normal routine of the screen sliding to it's open/down positon for CD loading. It indicated to "wait" to load CD (which is normal) and I waited until it indicates to "load" CD into the unit which it did not do.
2. After the screen locked into position, the procedure of loading CD just stopped and now the screen is stuck in the down position and not responding. When I push the button for CD mode, the LED console (the center console where the temp. is displayed) indicates that there is NO CD INSERTED eventhough there are 5 CD's inside (since last year). I was not able to load the the new CD I was about to put in.
3. I removed the battery for at least 15mins. to see if it will reset the unit. No luck. Checked fuses. All are good.
4. The screen still displays NAV, I can still listen to radio and I can still receive calls via bluetooth. However, CD mode does not work and backup camera not displaying on screen (screen still stuck in down position. Does not slide up to normal viewing position).
Wondering if anyone has experienced this issue and have found a solution for it. Kindly post any help.
Thank you in advance. Have a great day.
BTW it's a 2008 CX9 Grand Touring with NAV and Bose
