cougar10agREDUX
- 2003 Protege ES-T
Ok so... I have to redo my ignition maybe... I duno yet.. But I Will build the circuit tonight.
I do need a diagram for iac. Control.. Maybe if I cant find one ill leave it to the stock ecu..my engine is dune being built so it is going in this week.. And the testing begins...
I did my ignition tion a little different... I bought the second Bosch driver thing and installed it on q16 per the directions. So hopefully it works... If not.. Ill be removing it and installing it on the led thingy..
Q16 is the normal ignition coil driver spot. being that our coils have internal ignitors, you don't need the high power coil driver anyway, LED 14 and 16 control the coils. leave it installed for possible future use, it does no harm installed. but do not make any jumper connections for it.
for IAC, the 3.57 board already has the PWM circuit, thats one of the bonuses to the 3.57 board because it was a popular mod to the v3 board. so you just need to hook up the IAC valve properly then get the settings right
