ZealoustheEnder
Contributor
- 2003 MSP
Sweet. Put a Jack with a 2x4 under the engine remove the passenger side mount to get extra room to work.
it's not common for these cars to jump time.
I'll tell you, I had a similar experience when I first got my msp. Everything was running smooth when I first got it. I decided to Change the timing belt and water pump for preventative maintenance and to refresh the car, then the mechanic (who was a bad mechanic) recommended to replace the spark plugs. He replaced all the parts then accidently damaged the crank sensor, then the spark plugs were gapped incorrectly. After that EVERYTHING went downhill.I got all that fixed then the wires to my coil packs were damaged, then battery died, then brakes were grinding, then maf sensor died, then radiator went out, then needed new tires. I replaced the dead wastegate afterwards. I'm not saying that all the other stuff that went bad is the mechanics fault I'm just saying sometimes it takes a lot of money, patience, and time to get everything fixed due to the previous owners mistakes or lack of care, but once you get these things fixed its smooth sails after that. Trust me. There's been so many times I wanted to just sell/trade the msp due to these problems but just take it one problem at a time. To this day I'm very happy I kept it. By far, the funnest car I've ever driven. I've driven in Mercedes, bmws, supras, tc's, etc.
Waiting for ebay stuff gives you too much time to brainstorm... I would have just gone to a parts counter and got the timing kit.. then you wouod be done by now and happy with your car....unless its confirmed actually ******, stop planning to spend money.
If your head comes off, you should plan it around a set of forged rods ect..
Just stay the course man. I get compliments on my car all the time. It's a good platform, it has its quirks but a solid platform.. nevertheless. You just have to learn how to take care of it. After this $3400 it should last you awhile.Thanks for sharing that. I really thought I was getting a "steal" at $2600 for this car. I really didn't expect to be this deep already financially (So far I am at +$700) I can't imagine what it would cost if I wasn't doing this work myself.. probably upwards of the cost of the car all over again..
My "purchased list"
battery
timing belt / water pump kit
timing covers
tensioner spring
crankshaft position sensor
plugs
wires
coil packs
coolant
rtv
oil / oil filter
full gasket set
head bolts
tap and die set
wheel stud
intercooler / piping kit
hours upon hours of R&D and work..
I didn't have to buy the PCV, or the valve cover gasket, or the Greddy Stage 1 clutch (that the car doesn't need yet)
So I saved about $20 there. LMFAO.
I still need a BOV and the adapter for it, and the intake / pod filter.. i might steal the intake off my other car (I saved the factory airbox for it)
I THINK that is it, for now... but YIKES, my credit card is taking a beating.. $2600 turned into $3400 really quick.
I am basically rebuilding most of the engine.. This car was bought and driven hard for 140,000 miles without much more than oil changes and tires, then sold off. (which pisses me off) I cannot even imagine all this being financially feasible if the work was being done by a shop.. no wonder these get parted out too often.. but I didn't buy a turbo car so I could part it out. The whole point is to have a decent platform to build on..
Don't pull the head man pull the radiator. That will give you the room you need. And save you a lot of hassle trying to pull the head and everything at night
