Mazda Competition & Factory Parts @ Racer net pricing! Go Tri-Point!
+ Reply to Thread
Page 1 of 10 1 2 3 ... LastLast
Results 1 to 15 of 148
Thread: How To: Electric Window Always On
  1. #1
    Registered User jrodhotrod's Avatar
    Join Date
    Sep 2002
    Location
    Silicon Valley, CA
    Posts
    3,407
    Donated: 10$
    HOW-TO: Electric Window Mod for Always On
    This was copied from an email that "Kirbert" originally posted to the mazdaprotege5@yahoogroups.com Yahoo! Group with his permission.
    User a223818 posted it here originally, I just re-formated it and added pictures so they would be at the top of the thread... Originally posted here without pictures.
    Quote------------------------------------------------------------------
    Am I the only one that gets p*$$ed off when I shut off the engine and
    then realize that I still need to open or close a window? Windows
    that are only operable when the ignition is on perturb me. If I'm
    the only one, the rest of you can delete this message without reading
    any further.
    Here is a step-by-step procedure for making the windows work whenever you push a button, regardless whether the ignition is on or not. It is reversible, so you can try it and then switch it back if you don't like it:
    1) Disconnect the battery if you're that kinda guy. I'm not, didn't
    disconnect it, dunno why bother with a job this simple.
    2) Remove the plastic sill cover from the driver's door opening. This involves grabbing it and yanking straight up.
    3) Peel the door jam seal up for about six inches near the fuse
    access door.
    4) Way back at the outboard corner of the footwell, remove one of
    those buttons that are removed by carefully prying the center dot up.
    5) Remove the cover surrounding the fuses. After steps 2, 3, and 4, this involves a yank.
    6) I'd call the thing holding the fuses a "fuse box" but Mazda calls
    it a "Joint Box" -- perhaps to distinguish it from the "Fuse Block"
    which is in the engine compartment. Anyhow, there are several
    connectors plugged into the back of the Joint Box; you need to unplug the one at the bottom, a connector designed for eight terminals in two rows of four but with only six terminals in it. You may choose to unbolt the Joint Box from the car (one Phillips screw and one 10mm bolt) to make this easier; I did.
    7) By looking into the two unused slots in the plug, note how a
    plastic tang inside retains each terminal. Then using a jeweller's
    screwdriver or a toothpick or something similarly pointy, pop the R/W terminal out of its slot, move it over to the unused slot next to it, and snap it back in there. You might want to cut away some of the black tape around the wires to make this easier. Before you started, that row of four slots was
    B/W - R/W - empty - empty
    but after you're done it should be
    B/W - empty - R/W - empty
    8) Plug the connector back into the Joint Box.
    9) At the bottom right of the array of fuses in this Joint Box,
    there is a large pink box-shaped 30A fuse for the power windows.
    Just above it, there's an empty fuse slot for the same type fuse.
    Pull this fuse, move it up to that empty slot, and plug it back in.
    At this point, you can test your windows (if you didn't disconnect
    the battery).
    10) Slap it all back together.
    11) On the back side of the fuse access door, use some white-out to indicate the moved fuse.
    You're done. It took a LOT less time to do it than to write this up!
    FYI, all the electricity in this car goes through three fuses. First
    there is a 100A fuse in the fuse block under the hood that protects everything. Then there are several 40A and 60A fuses in that same fuse block that each protect some group of circuits. Then there are many smaller fuses in the Joint Box that protect individual circuits.
    As should be apparent, the 30A fuse that protected the individual
    power window circuit will continue to protect it, although from a
    different slot. On the groups of circuits, the power window load has been taken off a 60A fuse in the fuse block labelled "IG KEY" and has been added to a 40A fuse labelled "BTN". This doesn't seem to pose a problem; in fact, as I reported a few days ago there's ANOTHER fuse labelled as being for power windows that actually does nothing, and that fuse was powered through the BTN 40A fuse. That may represent some earlier incarnation of power window wiring.
    As an alternative idea, one could splice in another terminal on that
    R/W wire and make it connect to both slots in that plug. With that
    arrangement, you could decide whether you wanted the windows to workwith or without ignition by simply moving that fuse back and forth between the two slots. However, you'd need to remember not to plug fuses into BOTH slots at the same time, because that would allow power to backfeed from one to the other and you couldn't shut anything off.
    Having the windows work without the ignition on isn't a security
    issue, since you have to be INSIDE the car to push a button. I made this same mod to another car more than a decade ago, and my wife and I have found no downsides at all, it's just far more convenient.
    BTW, the switch in the driver's armrest that disables the power
    windows will still work because it breaks the ground circuit to the
    windows.
    -- Kirbert
    2003 Silver Protege5
    {Racing Beat Exhaust, MP3 ECU, K&N Typhoon CAI, Tint All Around}
    2002 Nissan Sentra GXE - Wife's
    2006 Titanium Mazdaspeed 6 Sport -- SOLD
    Disco Potato Powered 2003.5 Blazing Yellow Mazdaspeed #1524 of 1750 - Sold
    MOCC -- Left Coast MAZDATEAM Member
  2. #2
    Registered User CruzinAltitude's Avatar
    Join Date
    Mar 2003
    Location
    Mo Val in So Cal
    Posts
    1,062
    Very handy work, between the original Mod, the write up and the How To with pics I think this is a MUST do for me!
  3. #3
    Olin PhreekPhive's Avatar
    Join Date
    Aug 2003
    Location
    Nirai-Kanai
    Posts
    356
    I'm bored, it's 1:30am. I'm on house watch until 5am cuz of all the fires in the area. I think I'm going to go try this right now. This looks toooooo easy.
    PROUD MOCC MEMBER SINCE 2003
  4. #4
    Registered User Reitrof's Avatar
    Join Date
    Jan 2003
    Location
    Nashua, NH
    Posts
    4,715
    Donated: $50
    Nice Job jrodhotrod.
    It has to be the easiest mod I have done. Well Done Kirbert.
    Bruce
    2008 Miata Touring PRHT True Red, MazdaSpeed body kit
    RB Intake, RSII Exhaust, RX8 Sways, MazdaSpeed Coilovers, Nautilis horn
    RX7 FD Rims, Kenwood DNX7100, Int Wiper Mod, 3M Bra
  5. #5
    TwoToned on 18's... Opps JrTekSilverP5's Avatar
    Join Date
    Apr 2002
    Location
    Kendall, Miami, Fl
    Posts
    1,612
    for some reason i cant get the R/W terminal out of its slot... is there a trick to this...
    2002 Two Toned Mazda Protege5
  6. #6
    Registered User
    Join Date
    Jan 2003
    Posts
    5,757
    Donated: 20$
    As much as I don't always agree with Kirbert, I've gotta give him credit. This mod rocks!
    JrTek, use a toothpick or super-small screwdriver to push up on the little plastic tab inside the plug. I used a screwdriver in one end of the plug, while I pulled on the wire on the other end. After a little persuasion, it popped out!
  7. #7
    CHICK W/A 'TUDE Cirielle's Avatar
    Join Date
    Apr 2003
    Location
    Chesterfield VA
    Posts
    477
    Donated: 5$
    Don't know if anyone would know this or not, but what if I wanted to modulate it to work with a remote??
    Someone got an easy how to do on that too?????????
    PYCH BLK 2003 BLACK MICA MAZDASPEED # 467
    Nihilist Bear
    Nihilist Bear
    Which Dysfunctional Care Bear Are You?
    brought to you by Quizilla
  8. #8
    Join Date
    Apr 2002
    Location
    Kendall, Miami, Fl
    Posts
    1,612
    tru.... thanx natey.... ima go try it now...
  9. #9
    New car? No $$$ :( glyph's Avatar
    Join Date
    Aug 2003
    Location
    Dayton, OH
    Posts
    2,757
    Donated: $30
    thanks for the good how-to, I'll do this when I get home.
    99 ES 1.8 | Highlight Silver Metallic | shaved mouldings | DaveB's Brushed Gauge Rings | Llumar Tint charcoal 35 side, 20 rear; smoked mirror 18 moonroof | clear corners | JVC deck w/ Infinity Reference 5x7s and 6x9s, XM Radio via Custom Mount Delphi SkyFi | Rage Vigors 17x7 metal | Potenza RE750 215/40 rubber | Espilir springs | AWR 21.5mm Sway Bar w/adjustable endlinks & Trailing Links & Front/Rear Engine Mounts | Custom Fiberglass hood from Maz1.8T | 626 Wiper Stalk | Mental Addiction Street Sleeper Turbo Kit
    "I'm not a crazed gunman, Dad, I'm an assassin...One's a job and the other's mental sickness!" - TF2 sniper
  10. #10
    Join Date
    Apr 2002
    Location
    Kendall, Miami, Fl
    Posts
    1,612
    YAY!!!! it worked.... thats natey... and mr right up man...
  11. #11
    Slow 350Z -> Fast Mazda3 Bijou-MP5's Avatar
    Join Date
    Oct 2002
    Location
    Catch me if you can...
    Posts
    3,818
    Donated: 5$
    he he things to do this weekend!!!
    MAZDA TEAM THE FUTURE OF BIOMEDICAL
    Sponsored by Protege Performance Source: ProtegeGarage.com
  12. #12
    formerly Midnightracer22 Midnight22's Avatar
    Join Date
    Jul 2003
    Location
    Phoenix, AZ
    Posts
    2,310
    first to do it from this forum lol, 2 nights ago
    Owned
    2003 Mazda Protege5 2.0L (ie chipmunks on steriods) 157k original miles, original clutch (drive it like you stole it)
    - Modifications: AWR front engine mount, removed resonators, Window Mod, Sunroof Mod, Foglight Mod, Blacked Out Headlight Mod, Oil in the Coolant and Coolant in the Oil Mod
    1992 Kawasaki Ninja ZX-6 - 14k revs ftw
    1994 Jeep Wrangler 4.0L work in progress
  13. #13
    ...and it was all yellow cbcbd's Avatar
    Join Date
    Jan 2003
    Location
    Seattle,WA
    Posts
    3,212
    Donated: 5$
    Awesome mod!! Thanks, took a second and is very useful!!
    Genius!!
    2002 Yellow Pro5 #100,994
  14. #14
    failed gym class Devilspawn's Avatar
    Join Date
    Sep 2003
    Posts
    2,717
    I hate ants... Especially Cletus
    I take that it doesn't affect the battery then. If not, maybe midnight can help me do it this weekend.
    CARE METER
    low
    |----*|-----|-----|-----|-----|-----|-----|-----|-----|-----|high
    * indicates current level of caring...
  15. #15
    Join Date
    Jul 2003
    Location
    Phoenix, AZ
    Posts
    2,310
    sure i can help ya with that just remind me to bring the tools i need, i need to make a pile in the corner of my room for stuff i need to bring...
+ Reply to Thread
Similar Threads
  1. Grinding noise when rolling window down
    By Monstermile in forum Protegé 5 (Protege5.com)
    Last Post: 09-03-2003, 03:27 PM
  2. Power window modules
    By KYREDP5 in forum Car Audio & Electronics
    Last Post: 07-16-2003, 04:05 PM
  3. Crack in the front window.
    By AkiraFist in forum MSP Archives
    Last Post: 02-16-2003, 06:51 PM
  4. back window jets leaking?
    By adzampro5 in forum Protegé 5 (Protege5.com)
    Last Post: 02-21-2002, 09:37 PM
  5. barcode in window?
    By Kooldino in forum Mazda MP3 (MazdaMP3.com)
    Last Post: 01-28-2002, 06:09 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
