Sex change. Erm... tranny change question
2k2 Pro 5
Swapping the ATX with an MTX but i just found out it was from an MSP. Does anyone know if there is any issues with it being an MSP tranny?
Oh... i have an 02 pro5
There is no speedo connection on the MSP trans because it reads the ABS Wheel sensor. So you wont have a functioning speedo without adding it to the MSP dif.
If your P5 doesn't have abs the only thing you can do is pull the tranny again crack it opened and swap your pink speedo gear to the MSP lsd...sorry dude but youre the second person I've seen do this in the past couple days :(
You may want to have the msp lsd casing welded for strength since they are a common problem if any kind of power is in your future.
heh... where can i find this pink speedo gear? I am doing a p5 automatic transmission to an msp manual transmission. Can this be found on the auto tranny? If not does anyone know the part number or someone who might be selling one?
Oh yeah, if you already have ABS on your Pro5, I reckon you dont need to worry about the pink speedo gear.
Latest posts
