M makvli199 Member : Mazda Protege Mp3 May 23, 2007 #1 i have a friend selling me some work wheels for a good price with tires. i am not dropped still on RB's but its 18x8 and the tires are i think 225/35/18 would they fit or do i need spacer and who sells them for a good price.
G geomatics_tech : Titanium MazdaSpeed Protege May 23, 2007 #2 7.5" max width, 8" will fit if you roll the fenders. You need +45 offset minimum.
M makvli199 Member : Mazda Protege Mp3 May 24, 2007 #4 it is a 45 offset i am going to put them on i believe today to try them is there anything i should be aware of when i try them like any noise etc.
H haze20 : 03.5 MSP Titanium, 11 EVO X WW May 24, 2007 #5 When you put them on check to see if the tires are hitting anything. I hope it works out for ya.
N njaremka Wiggity-Wack-O-Tack Contributor : 2012 Mini R55 May 25, 2007 #6 towards the strut side, you should be fine - you will be rubbing the fenders unless you roll them rx-8 rims are 18x8 with a 50 offset, and they will only work without rolling if you go with a 215/35 tire.
