im looking at some wheels that are 17X7 42+offset, with 205/45/r17 tire, and will eventually lower it. i read the recipe but does goning with 205/45r17 over a 204/40/r17 make a difference with the rubbing
you wouldn't know till you lowered at that offset probably... but you probably would be ok... and if you do start to rub then just roll your fender a little.
