Striker187
- 2008 MS3 GT
i looked at rishie's fitment guide but i'm still not sure....am i gonna rub with 17x7.5" wheels with 215/45/17 tires? or could i fit 17x7" with +42 offset even?
The stock set up as per mazda is around 0.9 or -0.5, it saves tires and causes understeer for 'safety' reasons, with about 1.5 inch drop people suggest camber bolts, which I did so I don't know if I could have done with out them...anyway...Eibach pro-kit is a good choice for springs, my H&R's handled great but the rear was always to high for my liking, most protege springs are not designed for the speed, there is something different in the rear strut design.MoJoeTCM said:what happens to the camber when you add sportlines? if stock is -0.5?
I just did the H&R camberbolts, I think eibach makes some...and go to delsingmotorsport.com to turn the strut bearingStriker187 said:^^^^
according to rishie's guide, you'll need a +48mm offset, though you may be able to run a +45.
mavespeed, what camber kit did you get?
