Our motors don't blow from overheating, they blow because of the weak-ass internals being stressed beyond their design limits, sometimes on stock boost. It's perfectly normal for modern-ish engines to run at higher temperatures with pressurized systems. Both the antifreeze mix and the cooling system pressure raise the boiling point way above the 212 of plain water, sometimes it gets as high as 260, so temps in the 220-230 range aren't unusual at all. Higher temps mean more efficient combustion, as well as more efficient cooling due to the higher temp differential between the radiator and ambient air.
