What have you done to your Miata today?
Got new toys for her
well after a stressful month of things not going as planned (also a nail in my new azeni)I finally finished with the miata's suspension. I installed some apexi coilovers 8k front and 6k rear, energy suspenion bushings throughout all the arms also the diff bushings, swapped in larger NB miata brakes, installed cannon rear subframe brace to replace my bent 949 brace. now all i need is a decent paint job.
Has anyone got BC Coilovers on there MX-5?
Any good?
I'm looking at either Tein SS or BC Coilovers
Teins are double the price or there abouts
Haven't heard much from the BCs
i have bc's in the protege, install was easy, the stance, adjustabilty is great...but since the cold weather has set in, my ride is very "bouncy" i've adj them 6 ways to sunday and haven't had much luck...but the good weather ride was fine! some have complained of broken tabs??? if i was going to change out my suspension on the msm, i'd prob go with something different though..
Head gasket, valve cover gasket, 949Racing end links and a rattle can of Crystal White paint are on the way. I'm working on the wife to take advantage of the current 25% sale on Konis and get a set of yellows.
Saturday is gonna be busy
radiator and hoses replacement, timing belt, water pump, thermostat, accesory belts, valve cover gasket. . .. . . i know there are more parts in the boxes in teh garage, just can't remember what they are. . .
Nice, and good luck :). Give me or Kevin a call if you've got any questions about doing the head gasket work and we'll set you right.
Any good?
I have the BCs on my car. I can adjust them to be softer then the mazdaspeed bilsteins or to back breaking. The way you adjust the height does not mess with how much suspension travel you have either. Over all i like them, but i have not had the chance to take the car to a race event to really put them through their paces.
I took my Mazdaspeed mx5 stock IHI RHF5 turbocharger apart & took a lot of pictures.
New stock IHI RHF5 turbocharger
piston ring & thrust collar
thrust bearing
journal bearing turbine side of turbo
shaft rotor turbine wheel (coking)
turbine wheel
rotor assembly
cartridge
Thanks for that
So from the sounds of things you don't rate them worthy of putting into the MX-5
Any idea when you will be
I'm in no rush to get them
In fact I may even decide not to get any at all
Removed cheap ghetto craigslist HID kit previous owner had installed on my car, and installed a set of HALO Isis Blue H4 Bulbs, keeps it near the same color but I now have high and low beams. This weekend will be finishing what i started and relocate the individual toggles for headlight motors to inside the armrest and replacing the missing radio bezel and hazard/foglight switch.
Latest posts
