Can you make a how to on this? Do you happen to know if it will work on US versions?
Changed my oil, installed the 'tow hook' license plate bracket and applied wipe new to the plastics. Idk if the corksport bracket is any different, but mine sticks out past the bumper about 2" which I am not a huge fan of...the wipe new looks fantastic so far. I will see how it holds up and get an after picture of the bumper. My plastics were very light grey before cleaning thoroughly. Lots of left over wax/sun iita/media/License1.jpg.html][/URL]
Adjusted the wheel pressure ...The warmer Temp these days go along with the variation of the pressure in the wheel which leads to a confusion of the control system...
I have been keeping an eye on my TPS with exactly this variation in mind. I had all my tires filled with Nitrogen from Costco and have been very happy to not see or hear a blip from the TPS system from 85 degree days of summer, to a few low-mid 40's iv been in so far.
If you do have the option, get Nitrogen in your tires!
I pumped up all four road tires from 30 to 39 psi yesterday morning as the temperature had dropped to 41F and it was 87F just on Wednesday! The spare was 42 psi and I pumped it up to 61.5 psi.I have been keeping an eye on my TPS with exactly this variation in mind. I had all my tires filled with Nitrogen from Costco and have been very happy to not see or hear a blip from the TPS system from 85 degree days of summer, to a few low-mid 40's iv been in so far.
Strangely my TPMS warning indicator hasn't got triggered once after all of the tire pressure adjustments I've done even though I have never reset it like the manual said.
Getting nitrogen in tires? I've seen many tests and reports on this and none of them supports nitrogen is good for reducing tire pressure variation due to temperature change. I think nitrogen-fill by Costco is simply a grimmick.
Straightly from CX-5 Quick Guide:If you adjusted the air pressure evenly in all of your tires the TPMS won't display an error. The system looks at the difference between each tire's pressure and if any one is different from the others, set when the system is reset, then it tells you there is a problem.I pumped up all four road tires from 30 to 39 psi yesterday morning as the temperature had dropped to 41F and it was 87F just on Wednesday! The spare was 42 psi and I pumped it up to 61.5 psi.
Fully detailed and waxed mine
I hate to be THAT guy, but has anyone figured out how to debadge the the 'Skyactiv' off the back of the 2016.5?
That thing is so close to the body of the car, I can even get under it with a credit card. Is it screwed in? Any Advice? Looking for some help
