that info from your thread is dated, and incorrect...at least some of it...
Our Ford EECV ECU runs a low load closed loop cycle at lower rpm...that is self explanatory....this is to keep emissions and fuel consumption low as long as possible, but for reasons beyond the scope of this post;...once load increases the engine requires a richer mixture than stoichiometric...
closed loop refers to the way the computer is "reading" things...its a circuit in which information comes from the exhaust as well as some other sensors to incorporate fuel...it is "learning" after every few cycles, and changing accoringly...open loop refers to a system in which the ecu relies soley on predetermined maps...the maps have certain requirements, and the ecu uses a few sensors to determine which map fits the engine's condition (load rpm, etc...)
and WOT is NOT the cutoff...it is totally controlled by load and rpm...not throttle position...Our ecu will click into open loop at different times depending on what is going on... in which exhuast readings are halted for fuel corrections and mostly runs soley on the MAF for fuel/spark map determination (this is in stock form, not at all what aftermarket ECUs generally do)....but it happens around nearly 4000rpm at WOT, but can stay in closed loop longer when light on the throttle...
Most aftermarket computers with "self learning" can utilize a more complex "high load" closed loop...which incorporates a wide band O2 sensor...I never cared for these high load features for reliability reasons (adjustments are made to the cylce after a couple "foul" cycles occur...I hate that)...but our stock computer does not do this...it switches to open loop in these situations...
Open loop is where our terd computers really start to dump fuel...all the way to low 10s A/F wise...that is ridiculous for our engines...My guess is that it is to allow an FS to run almost always on bad U.S. gasoline...not a lot of power/detonation/heat can be made relatively when things are that rich...
