mazdarx7power
i'm looking for an amp to run my side speakers?? my budget is no more than $150 including shipping.... these are my current speakers i'm not sure if the kappa still work as they got a little wet but if they dont i plan to get another pair of kappa's and also some infinity tweeters to put in the back. also i'm a little confused with the ohm, does it matter that one pair is 2ohm and the other pair is 4ohm, does it have an effect on the amp???
<DT>infinity 6012i Reference Series <DT class=even>Speaker Type 2-way - Passive <DT>Speaker Diameter 6.5" <DT class=even>Nominal (RMS) Output Power 60 Watt Max (RMS) <DT class=even>Output Power 180 Watt <DT class=even>Response Bandwidth 53 - 21000 Hz <DT>Input Impedance 4 Ohm <DT class=even>Sensitivity 92 dB </DT>
<DT><DT><DT><DT>infinity kappa 682.7cf<DT>Speaker Size 5" x 7" / 6" x 8"
Design 2-Way
Tweeter Design N/A
Tweeter Composition N/A
Woofer Composition N/A
Woofer Surround N/A
Sensitivity 94 dB
Frequency Response 40 - 25 k Hz
RMS Power Handling 100 watts
Peak Power Handling 300 watts
Impedance 2 ohms
Top Mount Depth 2-1/4":
</DT>
Design 2-Way
Tweeter Design N/A
Woofer Surround N/A
Sensitivity 94 dB
Impedance 2 ohms
</DT>
