Brannon9827
- 2003 Mazdaspeed Protege
So I did a rebuild on my MSP and installed forged rods and pistons as well as had everything resurfaced. Well now I have everything together and the car will not start. So first I checked to make sure all the wires were correct and they were. Then checked the sparkplugs and they all spark. So I did a compression test and there was no compression. The car is also in time. So I thought maybe by accident I put the cams on the wrong side, but I checked and they are correct. Then I checked the spacing between the shims and cam and every one of them are extremely tight against the shaft. I did a smoke test and found out that air was coming in from the intake and out the exhaust at the same time. So now I am confused, does this mean the machine shop messed up? Do I need to get new valves, new shims? If anyone has any advice or even if this has happened to someone before please help. Thanks
