The feature of this TPMS Pressure By Location Display says “when tire is in an abnormal situation, you won't be able to identify which tire needs maintenance with your OEM TPMS. Installing TPMS display which works with OEM TPMS, you can see tire temperature and pressure by location.” However what the learning procedure is, the device can figure out the location of each TPMS pressure sensor.
I used my crap Chinese translation filter on the sentence beginning "When tire is in an abnormal situation" to mean that, when it doesn't work on its own (because its not designed to), don't worry, you can still train it.
I wouldn't read that literally. The reviewer's experience seems to indicate training is required. I don't think he had his TPMS sensors in the trunk.
