You should be able to tap into the 12v outlet or the cargo light. They are not in the hatch itself but they are close.
as gengas mentioned, the 12v outlet is constant.
anybody know if the cargo light will automatically shut off if you leave it on after x amount of time, like other cars? i assume not.
i reaaallllly dont want to pull up trim and run a wire from the front....ugh
You might be able to re-wire the power source for the 12v outlet so that it switches with the ignition switch...er, ignition button. Something like was done in this thread - http://www.mazdas247.com/forum/show...-12V-socket-to-Switched-(Accessory)-operation
I don't have time to research it any further right now but I might look into it later for my own curiosity.
