S ScottPro5 Member : 2006 Mazda 3 2.0 Apr 6, 2005 #1 does anybody know what size belt or belt i need to use?
F Fade Member : Mazda (duh), P5 Apr 6, 2005 #2 GOZA5 has the UDP and the indigo ones. He can get the part numbers. Trial and error to find the right size.
O ogsp5 225 whp @ 8psi : 2002 p5 (MSP Powered) Apr 6, 2005 #4 ScottPro5 said: does anybody know what size belt or belt i need to use? Click to expand... I thought you get a set of belts with your order| If not check with SR motorsports and let them give you the belts sizes(wrc)
F Fade Member : Mazda (duh), P5 Apr 7, 2005 #5 He has UR UDP. The indigo pulleys don't give a belt to use with the UR UDP
M melicha8 Member Apr 7, 2005 #6 one thing you can do to get the length is install the pulleys and measure the length the string has to be to meet itself again. It's a bit crude but I would error on the high side so pick something a bit longer than the length of the string.
S ScottPro5 Member : 2006 Mazda 3 2.0 May 8, 2005 #7 i got the right size belt but i still cant get the altenator pulley off. do i have to take of the altenator?
T twilightprotege Member : 2001 323 Astina SP20 (P5) May 8, 2005 #8 to change the pulley most definately otherwise it would be close to impossible.
