I don't know why anyone would regret it. The CustomMSP SMIC is far superior over the stock. I run around in 115 degree weather and it was a night and day difference.
The hard pipes don't do anything at all. The plastic does not flex enough to make any sort of difference in response, nor would it really help or hurt cooling.
The plastic does tend to crack over time, and the hard pipes have the advantage of being able to customize things.
By going to hard pipes, I could run the boost source to the WGA right off the turbo outlet which is the single best mod I've ever done. They also will let you relocate the MAF which the car will also run much better with. You can then run a VTA BOV instead of the tiny stock bypass. You can still recirculate if you don't want the ricerific psssh. It also allows you to add IATs for monitoring or tuning. All of these are wonderful things, but the pipes themselves don't offer any performance advantage.
I chose not to go to a FMIC for a bunch of reasons. One, it blocks air to the condenser. The Protege A/C is weak and it barely passable on those 115 degree days. Two, it is more volume of air for the turbo to pressurize before the IM sees the boost. This translates to slower response and more turbo lag. People swear it isn't bad, but it is definitely less responsive, and I will not do anything to this car that makes it less responsive. That is the huge advantage it has over any other turbocharged car I've ever driven.
