So I picked up a UHaul version from a guy that bought it but already had the factory hitch and didn't want to put the 2" on. Anyways, I got the hitch installed however did anyone else notice that the hitch doesn't fit 100% flush with the side rails? Somewhere around a 1/8" gap on both sides? I think this is a problem. Bolts need to be in tension, not shear force. There is significantly less strength as they aren't designed to be in shear. We took it out, adjusted the side arms so they mounted flush. I consider this a major flaw to this hitch and am concerned with towing with it close to max tow rating. I read the reviews on eTrailer and it doesn't seem to be an isolated case. How did your installs go?
