What type of noise is it? like squeaking, rattling.
Do you hear it when going over big bumps on a potholes in high speed / low speed,
or you hear it on a smooth road going over small imperfection like a repaired patch work on a road in high / low speed. Does it sound like two plastic components hitting or a wire on plastic I will send the pictures of the duct soon. try these to see its not these suspects.
1. Push as hard as you can with your Right leg and Right hand together on the console in the direction of the arrows. To eliminate the console. Do in speeds less than 40mph slower the better.
2. After that secure the Seat belt passenger side and go over the bump the slowest speed you think you will hear the rattle. to eliminate the seat belt.
3. I will show the duct after I get access to it. You need to be a little flexible and need flash light to take that picture under the Glove box.
