r0adie4950
- 2002 mazda protege 5, 2.0L
i recently had a new radiator installed by the dealer and after several weeks i opened up the hood and i noticed that the reservoir was empty and the radiator itself had to be topped off, there is a small hose coming off the radiator that had come loose and i pushed it back on and filled the radiator/reservoir but when i went to check the radiator the next day the radiator had to be topped off again.
i took the car back to the dealer and had them try to find out the problem, so they said they did a pressure check and nothing was leaking but also installed a small clamp to the small hose (I'm pretty sure there was no clamp there before), i checked the radiator later tonight and i see that the radiator is not as full as this morning when i topped it off, any hints as to what is going on?
