questions about cobb sri??
I read acouple of the post on the forums but does the sri intake cause any cel??? what should i know about issues with it?? i also want to know if ill get a cel with the forge bpv from su? thanks
Cobb sri has the air straightener for the MAF, so you shouldn't get any CELs from it. Just make sure there is no excess oil on the filter or filter frame as it could get sucked in and gunk up the MAF sensor. BPV shouldn't cause any CELs, but if it's a big concern you could just get a scan tool from your local auto parts store.
No Cel's if you install it properly. BPV wont cause any problems unless you dont clamp everything down properly.
Latest posts
