Ok that helps a bunch. I actually work as a tech for electronics so i was wondering if it were numbered on the board itself which it seems like it is.
Updated news about the car, it has a bad wastegate. I noticed it would not get the full 7psi that it should be getting, but im new to the turboed engines and just thought maybe just a bad vacuum line somewhere. Also when i would boost it would go to around 5psi max and then drop to around 3psi. Does that sound like a bad wastegate or should i check into another shop for a second opinion? I'm kind of tight on money after the purchase of the ssafc is why i am asking.
Also would the Wastegate replacement be an easy job for me to do? I plan on getting a CAI soon but didn't really look up too much info on the installation as of yet. I read that it is connected near the turbo and i think I have seen it before but not 100% sure on how to go about changing it. Guess my question is, should I just change it whenever i install the Injen CAI? would that make it easier since ill be replacing a lot of the piping anyways? Or is the wastegate in a totally different location? Another question is if I would happen to replace the wastegate, which type of wastegate should i buy (brand wise)? I plan to run at max 10psi once money and time is not an issue. Also what are the average dyno or butt dyno numbers that you can run at 10psi with basic bolt ons (not forged)? Just curious.
