Question about Replacing Driver's Seatbelt
smetzger
03 P5 (x2), 09 Miata, 07 Mazda3, 13 Fit, 09 Ody
Drivers seatbelt is starting to fray on my 02 LX.
Looks like I just need to remove the trim, and unbolt some bolts. Probably a good idea to disconnect the battery.
Am I missing something or is it this easy?
Yeah, that's pretty much all there is to it.
You might want to get the receiver part for it as well, while you're at it.
My receiver failed and wouldn't accept the seat belt latch any more.
Luckily I have a parts car and it wasn't too hard to swap it out.
If you get both parts, keep in mind that there is a switch in the latch that turns your seat belt light on and off.
Yeah, receiver has already been swapped out.
Looks like the two sides are interchangeable.
Yup, pretty easy. I think the two sides are interchangeable. But I got a driver's side from the pick and pull so I did not test that theory.
Latest posts
