You see, now here's the problem. The references you guys are using, all refer to LARGE AND HEAVY-ASSED CARS. It takes much more hp to make a 3700lb car drop .1 in the 1/4, than it does a car that only weighs 2300lbs. Fact is, I used to have 110.9whp and my car weighed 2500lbs and I did 16.3 in the 1/4. I took 150lbs out of the car, and added 6.3whp, and it dropped to 15.7. You do the math.
Not only that, you guys are talking about cars that already have large amounts of hp. An increase of 300 to 310hp is not a large gain percentage wise. An increase from 110 to 120whp is almost 10%, whereas the latter was only a gain of 3%.
http://www.supermotors.org/resources/calculators/index.php
Use the 'estimiated time and trap speed' calculator. Now enter in my 2650lb wet weight(I weigh a hefty 300lbs), and my car's 134 crank hp(assuming 14% drivetrain l loss), and you'll see it gives you a near exact replica of my best drag time. Now, take 50lbs off the weight. Yep, exactly. Now add 5hp. WHAT? .2 seconds? That's insane.
Now try if differently. Now make the car weigh 4900lbs with 300hp. Now drop 50lbs. Yep, 5/100ths. Now another 50. 1/10th. And add 10hp. This does even more on a large car than you'd think.
You see, things are different in the sport compact world. 50lbs are good for .1 seconds, and 5hp is good for .2 seconds.....
