Hey guys im a ford guy and not familiar with mazda setups, that being said my girlfriends dads car is a 2002 mazda protg and on his way to work he went to shift up and the clutch pedal depressed with no resistance. he had to cast off the road as his pedal wasn't functioning properly. I am not able to get it into a gear so I towed it home and im going to look at it tomorrow. problem is as I stated above im a ford guy so I don't know what systems these run. is it a hydraulic clutch? does it use the brake fluid reservoir? and are there common clutch issues I should address and inspect while im under it? thank you all in advance, im just trying to educate myself and prepare myself for inspecting and repairing this.
