Ok guys in a recent thread, we were talking about relocating the MAF.
Basically what happened was the other day, I popped the clutch while the car was at a dead stop and in reverse. When the car stalled, it shook and the MAF smacked the battery box with some avengence. Now it is running pig rich and lower power.
I took some readings off the MAF and am hoping that a few of you can do the same and report back.
With the car turned off and the key in the ignition, I read 1.48 V with a voltmeter's black lead connected to ground and the red lead connected to the center wire. I was told it should be around .5.
Then I disconnected the connector and measured the resistance of the MAF. From pin A to pin B I measured 14.80 K ohms. From pin A to pin C, I measured 6.8 k ohms. Once again with the car turned off andthe key turned to the ON position.
Just in case anyone needs to ask, there are three pins going from left to right on the MAF. What is left to right you ask If you are looking at the MAF with the air flow going from your left to your right while standing on the driver's side the pins are in order A B C.
Thank you for your time!
