DooMer_MP3
Experience my Member
Hi there,
2001 MP3 with ~60k, SPOOL springs, AEM intake and OBX header. When I am coming to a stop under light-moderate brake pressure, there is a popping noise that comes from the front of the car. It only happens when braking. If I were to glide to a stop in or out of gear, no. If I slow down to where the popping begins, and then switch to the e-brake (rear brakes), no.
I removed the pads and regreased the area where the front pads go with brake grease, and re-greased the bottom slides where the allen key goes on the caliper. My next step is replacing the front swaybar bushings since they already creak in the cold. This problem happens in cold, warm, dry or wet.
Any ideas? Could it be control arm bushings? Motor mounts? CV joint? I rule out CV joint since it only does it when braking which shifts weight to the front, hence my belief its the suspension...
Chris
Chris
