mazdaowner123
Ok, well, I just typed out a huge ******* post and IE decided it didn't like it enough so it made it dissappear. This day blows. Anyway, on to the issue.
I installed my JIC Magic FLT-A2's yesterday, and after some tweaking we got them in problem free. So today I get my car aligned, and lo and behold the tires are rubbing...everywhere. Front AND rear. I'm running -2.4 degrees of camber up front, and -1 degree camber rear. My question is this, would a 5mm spacer be sufficient to make the fronts and rears clear? The rubbing seems to be less so in the front, so I'm thinking 5mm will work. In the rears, the rubbing is substantially worse, so once again I'm wondering if 5mm will work. From what I could find they only make the spacers in 5mm, 15mm, and 25mm, so I think 15mm might make the tires rub on the fenders.
To make matters worse, I had to drive all the way from the alignment shop to the shop I put the coilovers in, with the tires rubbing the whole way. Who knows how badly it ****** up the s-03s. Nothing like smelling your $650 tires having the sidewalls ******. If anyone can provide any help I'd appreciate it, today has been a horrible day. Thanks in advance.
~brian
~brian
