Passenger low beam headlight problem
nalspeed
Contributor
mazda protege 5 silver
Alright my LB headlight on the passenger side keeps dying on me I don't know if something is wrong with the harness OR what I've had it change at least 6times already the past 2years or so and the one on the drivers side has only been change once!!!! i've just had it!! do you think I should take it to mazda and have them take a look at it? It can just be some electronic issue maybe? But they will probably charge me an arm and a leg for that and help will do
I think someone else posted about this problem recently, if I remember (without searching), it is just a loose housing, can be doctored up with some electrical tape...
you don't have warranty???
are you using aftermaket headlight bulbs or factory ones?
Latest posts
