My P5 tonight did the unthinkable. It currently has about 67K, was due for timing belt which I was planning...but...
While I was going about 50mph I heard what it sounded like something snapping then spinning really fast. I was able to drive about 1/4 mile and stop on the shoulder. Oh and before I pulled over, the engine was holding at about 2,500rpm...don't know if it was a good sign or not.
When I looked in the engine bay, the plug wire (2nd from right) was completely out. It was dark so I wasn't able to check and see other things. The two belts on the side were intact and I'm assuming my timing belt is not visible.
I did stick the plug wire back & restart it but the engine makes a weird noise and to avoid further damaging anything I just had it towed to the dealership.
Not sure if it's enough information but is my engine done? Is P5 non-interference or interference? If I understand correctly if it's interference design & the timing belt goes it's pretty much done? (Reading through the search I'm getting mixed answer on the P5 engine being which)
I don't even want to know how much it'll cost (or even worth it) to get this car fixed
