ok, so I have a problem, not sure how big or where to start, but when ever I start my car I have a really rough idle, and sometimes will even die. However, IF it makes it through the rough idle, it will go to a normal idle (almost like it needs to warm up). After that the car runs PERFECT, and I don't see any problems (no leaks or holes from what I can tell)... Soemtimes I will get the CEL, and when I check it it shows up at P0300 "Multiple random misfire". So far I changed the ignition coils and wires - not cheap =( - and it seemed like it solved it for a bit, but problem came back like a day later. My car is at 87,000 miles, it has new sparkplugs as well and I checked the spark plugs too and they look brand new still.... Where else can I look??
Someone said a leak in the head gasket, but if that were true, I wouldn't be able to run the car at all right? I'm gonna do a cpompression test, and I'm pretty sure it's going to be ok seeing as I did one like 1 month ago and it was fine.
I have a 02 mazda protege, 2.0L
Thanks for your help in advanced!
