qualityrockola
I'd say 85% chance its the thermostat, 10% chance water pump, 5% chance headgasket. A thermostat costs what? $10-$15 max? give that a try first, and its easy to replace.
Hughes412 said:If it was the water pump turning on the heater would'nt help. It might even make it worse because the pump would have that much more strain on it to pump the water through the heater core.
It's the thermostat.
Your too late! We all ready covered that. LOLBrian MP5T said:Coolant flows to the heater core regardless of the position of the dial. There is no "Magic Water Valve" just the fan does not blow over it so no heat comes in until you ask for heat, then the air is diverted over the core and heats the car.
I'm thinking it's not the thermostat, but it is such an easy thing to check that it should be your first start.
Does this happen every time you drive?
neodriftout said:Just to make sure everyone heard this part a will repeat it.
The car drove perfect for 2 years in the florida heat until now. With the heater on I drove easily 15 minutes with NO PROBLEMS with out heater I could only drive about a mile before she got hot. Just for the hell of it when I was close to home I turned off the heat to see what would happen and the car got hot immediately so I turned the heat back on and it cooled down just as fast.
