where is it? i need to cut into it to install my AF gauge. picture would be really much appreciated.. just circle the wire and i'm good
don't waste your time and money on a APC AFR
get the real deal, Wideband O2 Sensor....it'll save you headaches and when you are ready to tune, you'll thank yourself for getting a WB.
you didn't go cheap buying a MS3, why go cheap on this?
Our cars do come with wideband O2 sensors. You can read the values from a dashhawk or similar OBDII reader - which is probably what you should do. The only other real option for afr readings is to weld a bung onto your exhaust (preferably before the cat) and put your sensor there. The speed6 wideband O2 sensor is located immediately after the turbo on the DP.
