zdrpewter01
- 2008 mazdaspeed 3 gt
I bought an 08 mazdaspeed 3 grand touring and the issue it is having is it will start and idle fine but it has no power at all. If it is sitting there and you rev it it will raise the vacuum but as said will not build any psi. The motor takes forever to rev also. If I try to drive it it will die with any throttle given. The exhaust smells rich too. Any ideas are welcome just somewhere to start would be nice. I appreciate any help! I got the AP and fixed some issues I found after going over the car. Tightened all fittings, checked the vacuum lines, Cleaned out EGR/EGR tube/throttle body, changed rear 02 (wires were burnt from dangling), new plugs, and fixed a few stripped threads from previous owner. Only code is a U2064. Car is still doing the same thing. I took a video of me revving the car and how slow it is to rev. Ill get it up here asap.B2B2EE8
Modifications to the car are:
-Injen CAI
-Magnaflow exhaust
-COBB DP
-Street Unit BPV
*EDIT*
Ok so I took the car to mazda and 800$ later half the issue was fixed. The computer fried so I needed a new one, another key, and reflash. The car runs really good up until the point where you think about it having a turbo. It drives smoother and accelerates faster but only builds 2lbs of boost. No vacuum or boost leaks I've tested everything. Any ideas on what else could cause this?? I didn't know if maybe the wastegate being stuck open may do this?
-Injen CAI
-Magnaflow exhaust
-COBB DP
-Street Unit BPV
*EDIT*
