silvermsp88
- 2003.5 Mazdaspeed Protege
HELP!
Here is a list of problems that I need help with.
Front motor mount is f'd up, which aftermarket one should I buy?
the *SU one looks nice, any other ideas? Just found out that the side mount is out too! Should i go stock with that one?
Answer: SU front mount
The tranny sits on the bar under it!
The lower plastic hose is loose on my stock smic and will not tighten up.
Which smic should I but?
Fmic is too much, and Turbohoses has a nice V2 for cheap.
The radio is an aftermarket one and it sucks, but I need help with the sub. Its not working but the amp light is on. Any ideas?
Answer: sub blown- need new JL audio 8in sub
Whack ass radio
The car has green Tein springs on but the front is lower than the rear. I cant even get one finger in the front but the rear is like 1.5 fingers. Any ideas?
Answer: fake tein springs need new struts and really green tein springs
My rear sway bar is squeeking and its coming from the bushings, where do I get better ones?
Answer: replacement sway bar bushings from the dealer, not the originals.
I have a vaccum leak from the three way solenoid for the fuel pressure regulator, the nipple is broken from the solenoid, where do I get a new one?
Answer: $72 part with my discount from the dealer.
F'd up headlight connection!
Door panels not put back in right!
Zip ties for battery hold down.
Plus I have holes all over my dash where the meters used to be!
That should be all. PLZ HELP. THANKS!
Whack ass radio
