Okay, here goes:
I had a pending P0421 code for the last couple of days, indicating that my front cat is bad. It finally lit up on my dashboard this morning. Well I'll be damned if I didn't just replace the cat a year ago for the same code, and I haven't had any misfires or anything since that would ruin the new cat.
I hooked up my code reader to monitor my O2 sensor readings, and this is what I got (see attached image).
My rear O2 sensor isn't switching at all, which tells me that my cat is in fact good. However, notice in the bottom graph that my fuel trim spikes up briefly to 100% (I was idling the whole time these readings were taken, and nothing was done that would have caused the fuel trim to do this).
My question is does this fuel trim reading indicate a bad front O2 sensor, or an exhaust leak somewhere? Those are pretty much the only 2 possible causes of the P0421 code that I haven't ruled out. The front O2 sensor is only about a year old, but it doesn't seem from the graph that it is switching completely normal (notice the long time in the middle where it sits down near 0v).
Any help would be appreciated.
