Okay, well I recently I had to choose to replace my MP3 engine with one from a P5. Dropped the motor right in, no real troubles except for fuel pump not working like it should, so replaced that as well and it was right back on the road. Few weeks later put the MP3 manifold back on.
Now that I have covered what has been done here comes my problem. The car will at random start flashing the "check engine" dummy light and almost immediatly after it the car completely looses any kind of power it might have had on its 2.0L engine. Its like it were running on two cylinders. The car keeps running, but sounds to be in very poor health. With a quick pop of the hood, and unpluging the VICS relay (located on the top of the intake manifold) I can watch the accuator move and then plug the relay back up and the car runs just as good as it did the day it was bought...
What are your thoughts on this? I have an OBII scanner and when I check the trouble codes it always comes up with random misfires and mentioning 02 sensors every now and then.
Car may have a slight exhaust leak after installing the new engine, but would that cause this to happen? It really has me stumped I just thought I would ask for any input before I swap back to my original MP3 exhaust manifold and take it to an exhaust shop.
Would an O2 sensor cause a VICS relay to malfunction to the point of loosing power and having to be reset manually?
Let me know what you guys think, sorry for the lengthy post I just want to present you with as much information as possible. I will go plug up the trouble code scanner and right the exact information down if that will help.
THANKS!
//**cliffs** MP3 + P5 engine = VICS relay trouble. need input
THANKS!
