Hi,
I'm actually finishing to install a freshly built forged FS motor in our racecar and try to merge it with the Motec M48 that was driving the previous KL motor that was in that car.
I had a doubt about trigger polarity when I checked the cars wiring diagram so I've been reading most threads I found about coil drivers including MSII and HAltech install guide. From what I get FS coils have positive trigger ignition drivers built-in? The problem is I think my old Motec only supports sinking outputs so I'm not going to be able to control the ignition plug and play.
In your opinion, what is the best way to go: install other coil with or without external ignition module or use a driver to invert the signal?
Thanks for your help
