lavishauto
- 2007 mazdaspeed3
Ok, so my car has a miss fire. During the warmer months it would hardly miss. But now that it's colder it does it every time I drive it. I get why it would while cold cause the air is more dense allowing the car to make more power.
I had a sputter and I replaced the plugs, wires, and coils. The sputter went away with the new plugs and wires but it still had a miss. I thought it was faulty coils so I got a new set and it still had a miss. Mind you, the coils are from Autozone... Could the a coils be "cheap" and can't keep up with the cars power?
If the coils aren't strong enough, I'm gunna do the 1.8 conversion and see what that does.
OR could it be a fuel cut? I read that the reason there is a Fuel cut is that the car is making to much power and it cuts the fuel to keep you from blowing the motor. My waste gate is bad and is making me over boost. Could I be getting a fuel cut cause my wastegate is allowing the car to produce to much power?
