Antoine
Administrator
Congratulations to Mazdaspeed2oo35 (first)
Click below to ENTER in the next MOTM!
OPEN TO ALL MAZDAS!
*Mazda of the Month 2.0* VOTE now for February!
OPEN TO ALL MAZDAS!
Miguel Martin
Mazdaspeed Protege 2003.5
Engine: FS-DE 2.0 Liter Turbo
1. Honed and polished Engine Block.
2. Blue Printed and Balance Engine + Head
3. Sandblasted and black Powder coated engine block.
4. Crankshaft balanced and Polished.
5. Aries Custom Forged Pistons Lower Compression 8.1:1
6. Pauter Forged Chromoly Rods
7. Clevite 77 Main Bearing Set
8. Clevite 77 Thrust Washer Set
9. Clevite 77 Connecting Rod Bearing
10. Cometic Head Gasket
11. Greddy Timing Belt.
12. TBK Performance Custom Stage 3 FS-DE Head Blue Printed and Balanced to achieve 8,400 RPM Redline Limit.
13. TBK Performance Custom Turbo Dual Overhead Cams
14. TBK Performance 5 Angle Valve Job
15. TBK Performance Full Head Port and Polish Job
16. Ferrea 1mm Bigger Titanium Valves & Harder Valve Springs.
17. ARP Head Studs, ARP Washers, ARP Nuts.
18. SR Adjustable Cam Gears
19. ProtegeGarage Intake Manifold Single Runners with TBK Performance port & polish.
20. TBK Performance Port & Polish throtle body 60mm.
21. Throtle body Coolant Bypass
22. Unorthodox Ultralight S Underdrive Pulley.
23. Gates High Performance Engine Belts.
24. Apex Air diversion Plate
25. Mazda Millenia Supercharged PCV Valve.
26. Maxspeed Magnetic Oil drain Plug
27. Mazda Protege 5 Radiator
28. Ultra Slim HI Performance Radiator fans
29. Mazdaspeed 1.3 bar Radiator Cap.
30. Mazdaspeed BSpec Low Temp Thermostat
31. Mazdaspeed Gunmetal Oil Cap.
32. AWR 70a Bushings Front Motor Mount.
33. AWR 70a Bushings Rear Motor Mount.
34. Weapon R Engine Damper.
35. AEM Water/Methanol Injection Kit with 1 Galon Tank
36. Dual Walbo 255 in-tank and in-line Fuel Pumps.
37. RC 1000cc High Impedance Injectors.
38. Perrin Fuel Rail.
39. Haltech E6X Stand Alone Engine Management Air/Fuel,Timing, launch Control and Anti-Lag Features.
40. Haltech 3 bar MAP Sensor.
41. Haltech E6X Shift Light
42. HKS Super Sequential V2 Blow Off Valve Adjustable.
43. HKS Earth Ground Cables System.
44. Mazdaspeed Positive Charging and Voltage Stabilizer.
45. AEM GT35 Turbo Filter
46. Spearco Front Mount Intercooler
47. TBK Performance Custom Chrome 3 Front Mount Intercooler Pipes & Flanges.
48. Turbonectics Clamps.
49. Hiboost GT35 Big Turbo Manifold + TBK Performance Port & Polish
50. Garrett GT3582R Turbo with Stainless Steel Water and Oil Lines
51. TBK Performance 3custom downpipe
52. TBK Performance Custom 3.25 Downpipe back Exhaust with 3.25 Resonator
53. HKS Hi Power Muffler Chrome
54. Tial 40mm External Chrome Wastegate.
55. NGK IX Iridium Sparkplugs ( One Step Colder )
56. Haltech Coil Packs.
57. K&N 1008 Oil Filter
58. Royal Purple 20W50 Fully Synthetic Oil
59. Lucas Synthetic Oil Stabilizer & Protection ( New Engine Formula ).
Drivetrain:
60. Complete Transmision Internals Cryo Treated
61. Fidanza 7.5 lbs Flywheel.
62. DSS Level-2 Drive Axles
63. ACT Xtreme Stage 3 Racing Clutch.
64. ACT Xtreme Street Preassure Plate Disk.
65. Welded LSD front and back of it with Cryo Treatment
66. Racing Synchronizers with Cryo Treatment
67. TBK Performance Custom 600whp 3rd, 4th, Gears with Cryo Treatment
68. Techa-Fit Clutch Line.
69. Redline Shockproof Synchromesh Heavy-duty Transmission Synthetic Oil.
70. TWM Short Throw Shifter.
71. TWM Shifter Bushings.
Brakes:
72. Brembo Cross Drilled & Slotted Rotors.
73. Techa-Fit Stainless Steel Brake Lines.
74. Posi-Quiet Ceramic Low Dust Brake Pads.
75. Royal Purple Synthetic Brake Fluid.
Suspension:
76. TEIN Adjustable SuperStreet Coilover Suspension
77. GT Spec Aluminum Front Strut Brace
78. Racing Beat Front Lower Sway Bar.
79. AWR Front Lower Sway Bar Bushings.
80. AWR Adjustable Front End Links
81. GT Spec Aluminum Rear Strut Brace
82. Racing Beat Rear Lower Sway Bar.
83. AWR Rear Lower Sway Bar Bushings.
84. AWR Adjustable Rear End Links.
85. GT Spec Rear Trailing Link Set
Electronics & Interior Accessories:
86. OEM Mazdaspeed Classic Soft Trim 2 Tone Leather Interior Dark Charcoal with Titanium Gray + Titanium Gray Leather Door Panels.
87. Greddy Profec B Spec-II Eletronic Boost Controller (Silver).
88. Greddy Remote Switching System Steering wheel (Silver).
89. Greddy Full Auto Turbo Timer (Silver).
90. Maxspeed Engine Start Bottom (Blue).
91. Autometer Triple gauge pod (Black).
92. AEM Uego 6 in 1 Wideband Controller (White).
93. Auto Meter C2 Indiglow Pyrometer EGT 0-1600 Degree F.
94. Auto Meter C2 Indiglow 30 P.S.I Boost/Vacuum Gauge (White).
95. MRYELLERMP5 Custom Bezzel Dual Gauge Pod
96. Auto Meter C2 Indiglow Oil Preasure Gauge 0-100 PSI (White).
97. Auto Meter C2 Indiglow Fuel Preassure Gauge 0-100 PSI (White)
98. Maxspeed Cluster Indiglow Gauges 7 Colors with Dimmer (White)
99. Street Unit Cluster Polish Rings.
100. Maxspeed Chrome Cluster Bezzel.
101. Mazdaspeed Seat Belts Pads.
102. Clifford Alarm
103. Lo-Jack Satellite Security System
102. Clifford Alarm
Audio & Video
104. Kenwood MP919 Headunit CD/MP3/Sirious Radio/With Ipod Interface Controller
105. 7" widescreen Indash DVD-Player & TV Tuner NTSC/PAL
106. Apple Ipod 160GB Video
107. Kenwood PS400M 1200 watts Mono Amplifier 1 ohm stable
108. Power Acoustic 3 Fared Capacitor
109. Kewood PS300M 600 Watts 3 Channel Amplifier
110. Kenwood Titanium Tweeters ( 6 Tweeters )
111. Cerwin-Vega HD Series 4-way Front Doors Speakers
112. Cerwin-Vega HD Series 4 Way Rear Doors Speakers
113. Cerwin-Vega HD Series 4 Way 6x9 Rear upper deck speakers
114. Cerwin-Vega V-Max 12 DVC Subwoofers 400 watts RMS ( 2 12 Subs )
115. Rockford Fosgate 12 DVC Subwoofers 600 watts RMS ( 2 12Subs )
Lighting:
116. Euro Black Smoked Head Lights.
117. Bi-XENON Head Lights Kit. 8000k High & Low Beams.
118. Piaa Clear Rectangular Fog Lights.
119. XENON 8000k H3 Fog Light Bulbs.
120. Lexus IS350 LED Ultra White License Plate Bulbs.
121. Mazdaspeed Carbon Fiber License Plate Frame.
Wheels & Tires:
122. 2006 Mazda RX-8 Shinka Edition Wheels Gunmetal 18 X 8.
123. Nankang Ultra Sport NS-II 215/35/18 Tires Z Rated
124. Nitrogen on tires
125. Gorilla Chrome Wheel Nuts.
126. Gorilla Chrome Wheel Locks
